[GRASS-dev] [grass-code I][420] v.transform pointsfile does not
accept points in dd:mm:ss format
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Jun 11 10:42:23 EDT 2007
On 6/11/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> Dylan Beaudette wrote:
> > Out of curiosity, do the methods in v.transform accurately work with spherical
> > coordinates?
> No. v.transform performs an affine transformation, which doesn't
> really make much sense for spherical coordinates.
Ok- thanks for the affirmation- I was thinking the same thing. Would
it then be a good idea to include a warning as such?
dylan
