[GRASS-dev] simplify G_convert_dirseps_to_host(G_tempfile()) ?
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Jun 18 05:55:19 EDT 2007
On Mon, 18 Jun 2007, Paul Kelly wrote:
> On Mon, 18 Jun 2007, Hamish wrote:
>> [r.average]
>> should G_tempfile() be calling G_convert_dirseps_to_host() internally,
>> rather than having individual modules calling it? (ie often forgetting
>> to call it)
> I don't think so - G_convert_dirseps_to_host() only needs to be called in
> certain situations, when the generated path will be used directly by external
> commands on the system. I think to unconditionally call it would confuse its
> purpose. But then again in the longrun it might be a good idea to generally
> simplify things as you said. Hmm, I'm not so sure now. But there may be cases
> which call it and expect to have '/' directory separators there for some
> further processing; I wouldn't like to just change it without an audit of
> where it is used. Which modules were you thinking of anyway?
> FWIW I've attached my proposed changes to lib/gis/tempfile.c that I still
Oops - didn't even upload the diff never mind attach it. But here it is
now if anyone is interested. Interestingly, the patch forces all generated
filenames to have '/' directory separators - presumably because I was
concerned that some modules might expect this, although I can't remember
to be sure...
> have in my local source tree. They were intended to split the usage of
> G_tempfile() between modules that are genuinely using it as a tempfile for
> creating large temporary maps as was originally intended, and those that are
> just using it as a general small tempfile function. They also make some
> changes to make it more Windows compatible. But we decided they were too
> controversial to commit in case they broke things - maybe in some way we can
> eventually merge them though.
> Paul
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Index: lib/gis/tempfile.c
RCS file: /home/grass/grassrepository/grass6/lib/gis/tempfile.c,v
retrieving revision 2.5
diff -u -r2.5 tempfile.c
--- lib/gis/tempfile.c	14 Apr 2007 23:02:01 -0000	2.5
+++ lib/gis/tempfile.c	18 Jun 2007 09:17:45 -0000
@@ -11,36 +11,62 @@
  * \date 1999-2006
+#include <stdio.h>
+#include <stdlib.h>
 #include <string.h>
 #include <unistd.h>
 #include <sys/stat.h>
+#include <sys/types.h>
 #include <grass/gis.h>
- * \fn char *G_tempfile (void)
+ * \brief returns a temporary file name on the same disk as the current mapset
- * \brief Returns a temporary file name.
+ * This function returns a pointer to a string containing a unique file name
+ * that can be used as a temporary file within the module. Successive calls
+ * to the function will generate new names.
+ * Only the file name is generated. The file itself is not created. To create the
+ * file, the module must use standard UNIX functions which create and open files,
+ * e.g., creat() or fopen(). The filename is guaranteed to be on the same disk
+ * as the current mapset. This means that "draft" output maps can
+ * be moved (with either link()+remove() or rename()) into their final
+ * location upon closure.
+ * The programmer should take reasonable care to remove (unlink) the file
+ * before the module exits. However, GRASS database management will
+ * eventually remove all temporary files created by G_tempfile_in_mapset()
+ * that have been left behind by the modules which created them.
+ *  \return char:  pointer to a character string containing the name.
+ *   the name is copied to allocated memory and may be
+ *   released by the unix free () routine.
+char *G_tempfile_in_mapset(void)
+    return G__tempfile_in_mapset(getpid());
- * This routine returns a pointer to a string containing a unique
- * temporary file name that can be used as a temporary file within the
- * module. Successive calls to <i>G_tempfile()</i> will generate new
- * names. Only the file name is generated. The file itself is not
- * created. To create the file, the module must use standard UNIX
- * functions which create and open files, e.g., <i>creat()</i> or
- * <i>fopen()</i>.<br>
- * Successive calls will generate different names the names are of the
- * form pid.n where pid is the programs process id number and n is a
- * unique identifier.<br>
- * <b>Note:</b> It is recommended to <i>unlink()</i> (remove) the
- * temp file on exit/error. Only if GRASS is left with 'exit', the GIS
- * mapset manangement will clean up the temp directory (ETC/clean_temp).
- * \return pointer to a character string containing the name. The name
- * is copied to allocated memory and may be released by the unix free()
- * routine.
+ * The programmer should take care to remove (unlink) the file before
+ * the module exits. If a module requires not to immediately delete a
+ * temporary file and instead have it automatically deleted at the end of
+ * the GRASS session, G_tempfile_in_mapset() should be used instead.
 char *G_tempfile(void)
@@ -48,10 +74,7 @@
     return G__tempfile(getpid());
- * \fn char *G__tempfile (int pid)
  * \brief Create tempfile from process id.
  * See <i>G_tempfile()</i>.
@@ -62,6 +85,65 @@
+    char *env_tmpdir = getenv("TMPDIR");
+    char *env_temp = getenv("TEMP");
+    char *prefix, *path = NULL;
+    char dirsep_char[2];
+    static int uniq = 0;
+    struct stat st;
+    if (pid <= 0)
+	pid = getpid();
+    if (env_tmpdir != NULL)
+	/* This should be somewhere in user home directory on Unix,
+	 * thus ensuring write permission */
+        prefix = G_store(env_tmpdir);
+    else if (env_temp != NULL)
+	/* This should be somewhere in user profile directory on Windows,
+        prefix = G_store(env_temp);
+    else
+        /* Usually /tmp on Unix or root of current drive on Windows */
+        prefix = G_store(P_tmpdir);
+    /* Often there's no harm in having an extra directory separator character
+     * in the middle of a path but just being careful here. */
+    if (G_is_dirsep( prefix[strlen(prefix)-1] )) {
+	dirsep_char[0] = '\0';
+    else {
+	dirsep_char[0] = GRASS_DIRSEP;
+	dirsep_char[1] = '\0';
+    do {
+        if (path != NULL)
+	    G_free(path);
+        path = G_malloc(strlen(prefix) + 40 );
+        sprintf(path, "%s%sgrass-%d.%d", prefix, dirsep_char, pid, uniq++);
+        /* We use '/'-style dirseps within GRASS */
+        G_convert_dirseps_from_host( path );
+    } while (stat(path, &st) == 0);
+    G_free(prefix);
+    return path;
+ * \brief Create tempfile in current mapset from process id.
+ * See <i>G_tempfile_in_mapset()</i>.
+ * \param[in] pid
+ * \return Pointer to string path
+char *G__tempfile_in_mapset (int pid)
     char path[GPATH_MAX];
     char name[GNAME_MAX];
     char element[100];
@@ -78,13 +160,14 @@
     while (stat(path, &st) == 0) ;
+    G_convert_dirseps_from_host (path);
     return G_store (path);
- * \fn int G__temp_element (char *element)
  * \brief Populates <b>element</b> with a path string.
  * \param[in,out] element
