[GRASS-dev] [grass-code I][434] g.proj -wef command returns WKT string without prefix
grass-codei at wald.intevation.org grass-codei at wald.intevation.org
Sat Jun 23 12:29:54 EDT 2007
code I item #434, was opened at 2007-06-23 18:29
Status: Open
Priority: 3
Submitted By: Markus Neteler (markusn)
Assigned to: Nobody (None)
Summary: g.proj -wef command returns WKT string without prefix
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: None
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
Cross-bug from GDAL:
http://trac.osgeo.org/gdal/ticket/1656#comment:5
g.proj -wef command returns ESRI WKT string without the ESRI:: prefix, and that's why transformations fail.
To simplify user's live, we should add the prefix in case of -e flag specified.
Markus
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=434&group_id=21
