[GRASS-dev] [grass-code R][428] Warn about wrong epsg code when creating a location in grass 6.2
Michael Barton michael.barton at asu.edu
Sat Jun 23 13:37:16 EDT 2007
AFAICT, there is no way for the GUI to know if an EPSG code is bad. Perhaps
g.proj can test for this, but I wouldn't count on it.
The procedure to create a location from a georeferenced file is different
from the procedure to create it from an EPSG code, so I'm not sure what you
are referring to below.
Michael
On 6/16/07 2:39 PM, "grass-coder at wald.intevation.org"
<grass-coder at wald.intevation.org> wrote:
> code R item #428, was opened at 2007-06-16 18:39
> Status: Open
> Priority: 3
> Submitted By: Daniel Victoria (dvictori)
> Assigned to: Nobody (None)
> Summary: Warn about wrong epsg code when creating a location in grass 6.2
> Issue status: None
> GRASS component: startup
> Operating system: None
> Operating system version: Linux
> Initial Comment:
> When creating a location based on a georeferenced files, if the EPSG code is
> wrong there is no clear warning and no location gets created. This feature is
> already present in 6.3. Could it be backported?
> Also, if a wrong EPSG code is input a tmp directory sometimes is created
> thanks
> Daniel
> You can respond by visiting:
> http://wald.intevation.org/tracker/?func=detail&atid=188&aid=428&group_id=21
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
