[GRASS-dev] grass classification routines and small / large
numbers
Markus Neteler
neteler at itc.it
Fri Jun 29 03:59:26 EDT 2007
Dylan Beaudette-2 wrote:
> On Thursday 28 June 2007 06:42, Markus Neteler wrote:
>> Dylan Beaudette wrote on 06/26/2007 07:33 PM:
>> > Hi,
>> > I have found that using the GRASS classification modules work well when
>> > the inputs come from discreet (0-255) distributions- for example
>> landsat
>> > channels, etc. - however I seem to get a lot of singularity problems,
>> or
>> > maps with a single class when using floating point values of different
>> > magnitude.
>> Dylan, *,
>> there is i.pr available in the GRASS Addons repository from Stefano
>> Merler (my colleague from IRST):
>> https://grasssvn.itc.it/grasssvn/grassaddons/trunk/grassaddons/
>> * pr : C code for classification problems. It implements k-NN
>> (multiclass), classification trees (multiclass), maximum likelihood
>> (multiclass), Support Vector Machines (binary), bagging versions of all
>> the base classifiers, AdaBoost for binary trees and support vector
>> machines. It allows feature manipulation (normalization, principal
>> components,...). It also implements feature selection techniques (RFE,
>> E-RFE,...), statistical tests on variables, tools for resampling
>> (cross-validation and bootstrap) and cost-sensitive techniques for trees
>> and support vector machines. Feature selection techniques and
>> statistical tests are not distributed in the current release.
>> ||| * i.pr : a version of pr implemented in the GIS GRASS for dealing
>> with images.
>> Maybe interesting?
>> Markus
> This might be just the ticket. I was hoping to avoid a constant jump back
> and
> forth between GRASS and R (although it may be worth it...?) -- so the i.pr
> routines sound great. Any word on weather or not this module will end up
> in
> the main distribution of GRASS ? Perhaps I can do some testing and report
> back.
Yes, would be great. After a good testing period it should go into the main
distro.
Markus
View this message in context: http://www.nabble.com/grass-classification-routines-and-small---large-numbers-tf3983765.html#a11356553
Sent from the Grass - Dev mailing list archive at Nabble.com.
