[GRASS-dev] Re: [Quantum GIS] #736: Some GRASS commands broken
Markus Neteler neteler at itc.it
Fri Jun 29 09:00:18 EDT 2007
a colleague has found some strange problems in winQGIS/GRASS, signalled
to the QGIS team. I wonder if the problem could be GRASS related.
Hints welcome,
Markus
>    Reporter:  neteler  |              Owner:  nobody
>        Type:  defect   |             Status:  new
>    Priority:  major    |          Milestone:
>   Component:  GRASS    |            Version:  0.8.1
>    Keywords:           |   Platform_version:
>    Platform:  Windows  |           Must_fix:  No
> Status_info:  0        |
>  Hi,
>  some GRASS commands are broken:
>  r.median base=CEA_cat at CEA_dati cover=CEA_aspect at CEA_dati
>  output=aspect_median
>  Illegal filename. Character <'> not allowed.
>  Raster map ['CEA_aspect at CEA_dati'] not found
>  r.stats: ['CEA_aspect at CEA_dati] not found
>  Successfully finished
>  -> unclear why ' is present
>  r.mode base=delete cover=CEA_aspect output=del_aspetto
>  ERROR: r.stats: ['delete at CEA_dati] not found
>  ERROR: Raster map ['delete at CEA_dati'] not found
>  Same thing here.
>  But r.average with the same syntax works perfectly.
[unrelated]
> Ticket URL: <https://svn.qgis.org/trac/ticket/736>
> Quantum GIS <http://qgis.org>
> Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
