[GRASS-dev] [grass-code I][436] Concurrent quiet and verbose mode in v.in.gpsbabel
grass-codei at wald.intevation.org grass-codei at wald.intevation.org
Fri Jun 29 15:27:16 EDT 2007
code I item #436, was opened at 2007-06-29 21:27
Status: Open
Priority: 3
Submitted By: Carlos Dávila (carluti)
Assigned to: Nobody (None)
Summary: Concurrent quiet and verbose mode in v.in.gpsbabel
Issue type: module bad feature
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: None
Operating system version: debian testing
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
In the v.in.gpsbabel both quiet and verbose mode can be chosen at the same time. Isn't it contradictory?
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=436&group_id=21
