[GRASS-dev] cvs compilation problem - nviz?
Volker Wichmann wichmann at laserdata.at
Sat Jun 30 16:18:56 EDT 2007
almost similar to a recent post of Helena, I have problems compiling cvs
on a fedora 7 / NVIDIA machine. But I get another error:
Errors in:
/usr/local/src/grass-cvs/grass6/lib/ogsf
/usr/local/src/grass-cvs/grass6/visualization/nviz
Changing to /lib/ogsf and running make:
gcc -I/usr/local/src/grass-cvs/grass6/dist.i686-pc-linux-gnu/include -g
-O2 -fPIC -DPACKAGE=\""grasslibs"\" -I/usr/local/include
-DPACKAGE=\""grasslibs"\" -I/usr/local/include/ffmpeg
-I/usr/local/src/grass-cvs/grass6/dist.i686-pc-linux-gnu/include \
-o OBJ.i686-pc-linux-gnu/gsd_img_ppm.o -c gsd_img_ppm.c
In file included from gsd_img_ppm.c:20:
/usr/local/include/ffmpeg/avcodec.h:2252: warning: ‘ImgReSampleContext’
is deprecated
/usr/local/include/ffmpeg/avcodec.h:2258: warning: ‘ImgReSampleContext’
is deprecated
gsd_img_ppm.c: In function ‘gsd_init_mpeg’:
gsd_img_ppm.c:122: error: ‘mpeg1video_encoder’ undeclared (first use in
this function)
gsd_img_ppm.c:122: error: (Each undeclared identifier is reported only once
gsd_img_ppm.c:122: error: for each function it appears in.)
make: *** [OBJ.i686-pc-linux-gnu/gsd_img_ppm.o] Error 1
As far as I can tell ffmpeg is installed correctly (mpeg1video_encoder
is defined in config.h, no errors) ... any tip?
Thanks,
Volker
