[GRASS-dev] [grass-code R][319] v.distance: connect the output table= with the output vector=
grass-coder at wald.intevation.org grass-coder at wald.intevation.org
Thu Mar 1 13:43:01 EST 2007
code R item #319, was opened at 2007-03-01 19:43
Status: Open
Priority: 3
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Nobody (None)
Summary: v.distance: connect the output table= with the output vector=
Issue status: None
GRASS component: vector
Operating system: all
Operating system version:
Initial Comment:
Currently v.distance is able to output a lines vector where each line connects any 2 input points (-a output=), and it also can upload the required relation between each pair of points (upload=) into a table (column= table=). However, the output table and the vector are not connected. Which is too bad - if the two were a pair, it would be possible to extract certain lines from the output vector using SQL queries, based on the attribute uploaded to the table. That would make v.distance even more usefull.
Maciek
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=319&group_id=21
