[GRASS-dev] ps.map consolidation
Glynn Clements
glynn at gclements.plus.com
Fri Mar 2 01:17:47 EST 2007
Hamish wrote:
> > 2) I think, file session.c can be removed. I did not quite understand,
> > what is this session management about, but it would make the code a
> > bit simplier and short test showed, it is working also without it (and
> > I found no other function, which wuold access functions from
> > session.c)
> input() [input.c] calls add_to_session() [session.c] if PostScript level
> is >0 (???).
The parameter name is "level", but it doesn't refer to the PostScript
language level.
