[GRASS-dev] Re: gis.m, thematic layer: You must open a display monitor
Michael Barton michael.barton at asu.edu
Fri Mar 2 11:06:11 EST 2007
Thanks much Moritz
Michael
On 3/2/07 3:20 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> On 02/03/07 10:42, Maris Nartiss wrote:
>> Sorry, copy-paste introduced typo by me. Attached patch should fix
>> problem. Please, test and commit.
> Thanks, that was it.
> Committed to CVS.
> Moritz
>> Maris.
>> 2007/3/2, Moritz Lennert <mlennert at club.worldonline.be>:
>>> On 02/03/07 08:59, Daniel Calvelo wrote:
>>>> Sorry for the awful delay. I think the problems with d.mon select are
>>>> resolved; please test. I also made the legend cuts work for ps.map and
>>>> display managers. In CVS.
>>> I get the following error. The line
>>> format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)
>>> seems to be the problem.
>>> Moritz
>>> expected integer but got "1,"
>>>      while executing
>>> "format [G_msg "Legend for Map %d, %s"] $mon, $opt($id,1,map)"
>>>      (procedure "GmThematic::tlegend" line 11)
>>>      invoked from within
>>> "GmThematic::tlegend $mon $id"
>>>      (procedure "GmThematic::display" line 72)
>>>      invoked from within
>>> "GmThematic::display $node $mod"
>>>      ("thematic" arm line 2)
>>>      invoked from within
>>> "switch $type {
>>>          group {
>>>              GmGroup::display $node $mod
>>>         raster {
>>>             GmRaster::display $node $mod
>>>         labels {
>>>             GmLabels::disp..."
>>>      (procedure "GmTree::display_node" line 7)
>>>      invoked from within
>>> "GmTree::display_node $n $mod"
>>>      (procedure "GmGroup::display" line 22)
>>>      invoked from within
>>> "GmGroup::display "root" $mod"
>>>      (procedure "MapCanvas::runprograms" line 64)
>>>      invoked from within
>>> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
>>>      (procedure "MapCanvas::drawmap" line 38)
>>>      invoked from within
>>> "MapCanvas::drawmap $mon"
>>>      (procedure "MapCanvas::display_server" line 9)
>>>      invoked from within
>>>      ("after" script)
>> Index: gui/tcltk/gis.m/thematic.tcl
>> RCS file: /home/grass/grassrepository/grass6/gui/tcltk/gis.m/thematic.tcl,v
>> retrieving revision 1.25
>> diff -u -u -r1.25 thematic.tcl
>> --- gui/tcltk/gis.m/thematic.tcl 22 Feb 2007 15:45:29 -0000 1.25
>> +++ gui/tcltk/gis.m/thematic.tcl 2 Mar 2007 09:39:41 -0000
>> @@ -619,7 +619,7 @@
>> if { [winfo exists .tlegend($mon,$id)] } {return}
>> - set legendtitle [format [G_msg "Legend for Map %d, %s"] $mon,
>> $opt($id,1,map)]
>> + set legendtitle [format [G_msg "Legend for Map %d, %s"] $mon
>> $opt($id,1,map)]
>> toplevel .tlegend($mon,$id)
>>      wm title .tlegend($mon,$id) $legendtitle
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
