[GRASS-dev] ps.map consolidation
roger at spinn.net
roger at spinn.net
Fri Mar 2 17:25:06 EST 2007
I have a rudimentary GUI for ps.map written as a TCL/TK script. It works by
reading the content of the monitor and using that content to construct a
basic input file for ps.map. The GUI (which, as I said is pretty
rudimentary) allows the user to view and edit instructions in the input
file, to insert elements like eps files and to use options like line styles
that aren't supported on the GRASS monitor. It uses xpdf a previewer. xpdf
is fairly fast and has a remote server mode that allows the user to update
the preview without restarting the viewer. It is distributed under the GNU
public license by Glyph and Cog, LLC ; http://www.foolabs.com/xpdf/home.html
The grass developers may not want to introduce a dependency on xpdf, but I
encourage you to do something to give ps.map a friendlier front end. The
benefit is tremendous. Having even a simple interactive ability to develop
better graphics within the grass environment improved the quality of my
products and decreased the time necessary to produce them.
Roger Miller
Glynn Clements writes:
> J-B�chym �epick� wrote:-A
>> another point: How to write GUI for ps.map, so it is usable for the
>> user. Several approaches are possible:
>> Drawing boxes for legend, measure, text and so on, so the user has at
>> least idea about where and how the object will be placed on the paper.
>> Another sollution would be, if we would copy the map display approach:
>> render separate layer for each map instruction in the temporary file
>> and put them together in the map display. User could than take a mouse
>> and position each object interactively.
>> We would need support of transparency for this... Does ps.map support
>> creation of transparent files?
> ps.map creates PostScript files. If you use Ghostscript's "pngalpha"
> driver, the resulting PNG file will have a transparent background. But
> then you would need to convert the PNG files to PPM/PGM (that's all
> that g.pnmcomp understands), and you would need to manually
> re-composite those files whenever the relative position changes.
> Personally, I don't see the point in a ps.map GUI; this task is better
> suited to general-purpose DTP software.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
