[GRASS-dev] New feature (algorithm and / or module) to implent to
GRASS (long)
Markus Neteler
neteler at itc.it
Sat Mar 3 08:56:28 EST 2007
Hi Wolf,
indeed, a wonderful list of ideas - it's great to see this.
Like the others I would opt for "label position" (you will gain
most kudos like that in the GFOSS world :-)
The DP generalization might be rather easily solved using
the GMT/GSHHS code which probably needs "only" an update to
match the GRASS vector structure.
But labeling is a real problem for now.
Good luck,
Markus
