[GRASS-dev] [RFC] Glossary: GISDATABASE -> DATASTORE
Hamish
hamish_nospam at yahoo.com
Tue Mar 6 00:39:16 EST 2007
Glynn Clements wrote:
> And the GRASS variable has been called LOCATION_NAME for at least as
> long as GRASS has been in CVS (1999-12-29).
> The main issue is that we would have to fix all of the shell scripts
> which use LOCATION as the path to the mapset directory and expect
> "eval `g.gisenv`" to store the location in LOCATION_NAME rather than
> in LOCATION. But that's equally true whether we change it now or
> later.
c.22 scripts and lib/init/init.sh
grass63/scripts$ grep -rI LOCATION * | wc -l
83
grass63/scripts$ grep -rI LOCATION_NAME * | wc -l
53
grass63/scripts$ grep -rI LOCATION * | cut -f1 -d: | uniq
d.rast.leg/d.rast.leg
d.slide.show/d.slide.show
g.mremove/g.mremove
g.mremove/g.mremove1
i.image.mosaic/i.image.mosaic
i.in.spotvgt/i.in.spotvgt
i.oif/i.oif
r.fillnulls/r.fillnulls
r.in.srtm/r.in.srtm
r.mask/r.mask
r.plane/r.plane
v.build.all/v.build.all
v.convert.all/v.convert.all
v.db.addtable/v.db.addtable
v.db.reconnect.all/v.db.reconnect.all
v.in.e00/v.in.e00
v.in.garmin/v.in.garmin
v.in.gns/v.in.gns
v.in.gpsbabel/v.in.gpsbabel
v.in.mapgen/v.in.mapgen
v.in.sites.all/v.in.sites.all
v.report/v.report
Hamish
