[GRASS-dev] [bug #3069] (grass) r.mapcalc -
	warning/errorr	amibiguity
    Glynn Clements
    glynn at gclements.plus.com
    Tue Mar  6 05:45:28 EST 2007
Moritz Lennert wrote:
> >> r.mapcalc still prints this double information in case 2 same called
> >> rasters exit within the accesible mapsets, eg.:
> >> WARNING: 'cell/map' was found in more mapsets (also found in nic).
> As I've mentioned before somewhere, I find this message a bit confusing,
> especially the "also found in" which normally gives me the mapset I am
> in and want to use the map of (at least it does so when in mapset user1
> of spearfish working on a local copy of a map which is also in PERMANENT).
> Couldn't this be changed so that it mentions the _other_ mapsets the map
> is in, and maybe mention which map is used by default (I know that in
> this case it stops with an error, but many other modules just emit this
> as a warning, leaving the user uninformed of which map was used) ?
I've changed it so that it identifies all of the mapsets involved,
e.g.:
	$ r.resample in=fields out=fields
	Creating support files for fields...
	creating new cats file...
	$ r.mapcalc foo = fields
	WARNING: 'cell/fields' was found in more mapsets (also found in PERMANENT).
	WARNING: using 'fields at glynn'.
