[GRASS-dev] init.sh OSX browser setting
William Kyngesburye
woklist at kyngchaos.com
Thu Mar 8 12:06:56 EST 2007
[summary for list]
Two problems with the way GRASS opens help files in OSX:
Init.sh uses a plain 'open' as the default for the browser in Mac OS
X. This will open help files in whatever application a user has
their system set to open html files in. By default this is Safari,
but it may not be a browser but a text editor (ie for those web
programmers), and for viewing help that's not helpful.
And, if a user wants a different browser for GRASS (and doesn't want
to change their general system default browser), the normal unix
executable way is not right, that is setting, say, /Applications/
Firefox.app/Contents/MacOS/Firefox. This opens the application, but
if it's already running it opens another instance - not right on OSX.
The way to handle these problems is to add options to the open command:
open -a /path/to/app/package.app
or:
open -b app.signature
This causes a problem in the scripts, since $GRASS_HTML_BROWSER is
quoted everywhere - it tries to execute "open -a /path/to/app/
package.app" as the name of a program, not "open". So, I tried two
ways to handle this.
[/summary]
So far I have (in init.sh):
- alias method - doesn't work, command not found
alias opengrasshelp='open -b com.apple.helpviewer'
GRASS_HTML_BROSWER=opengrasshelp
export GRASS_HTML_BROWSER
Help button in GUI startup and help menu in GUI and in command dialogs:
couldn't execute "opengrasshelp": no such file or directory
or if I try to run 'opengrasshelp' from the GRASS prompt:
bash: opengrasshelp: command not found
- script method - an extra etc script html_browser_mac.sh opens the
help file in the browser set in GRASS_HTML_BROWSER_MACOSX
This works as a default browser:
GRASS_HTML_BROWSER="$ETC/html_browser_mac.sh"
GRASS_HTML_BROWSER_MACOSX="-b com.apple.helpviewer"
export GRASS_HTML_BROWSER_MACOSX
This also works:
GRASS_HTML_BROWSER_MACOSX="-b org.mozilla.firefox"
But this opens the default system browser:
GRASS_HTML_BROWSER_MACOSX="-a /Applications/Firefox.app"
It opens the default browser when used in the Help menu and dialogs,
BUT works correctly if typed at the GRASS prompt, like:
> $GRASS_HTML_BROWSER_MACOSX /path/to/some/hemp/file.html
I can use the browser signature method, and would prefer that - it's
simpler for the user, and I can put tests in init.sh for common
browsers so the user just needs to set GRASS_HTML_BROWSER to a
name. But I don't know the signatures for any other browser than
Safari and Firefox, so those would have to be filled in.
I could force the signature method as the only method. Leave
browsers that I know as above, but for other browsers the user would
have to figure out their signatures.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070308/c3979ea0/attachment.html
