[GRASS-dev] grass location creation
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Mar 9 07:52:18 EST 2007
Ok,
I also added brackets to make it a bit more safer for reading..
thanks
jachym
2007/3/9, Glynn Clements <glynn at gclements.plus.com>:
> Jachym Cepicky wrote:
> > general/g.region/cmd/main.c:
> > 851 if (flag.savedefault->answer)
> > 852 if (strcmp(G_mapset(),"PERMANENT") == 0)
> > 853 G__put_window( &window, "../PERMANENT", "DEFAULT_WIND" );
> > 854 else
> > 855 G_warning(_("You are not in mapset PERMANENT, default region -> remains untached"));
> > is it sufficient?
> 853 G__put_window( &window, "", "DEFAULT_WIND" );
> If you're already in PERMANENT, there's no need for "../PERMANENT".
> Otherwise, fine.
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
