[GRASS-dev] Re: [GRASS-CVS] martinl: grass6/vector/v.distance
main.c, 1.36, 1.37
Martin Landa
landa.martin at gmail.com
Fri Mar 9 11:10:43 EST 2007
2007/3/8, Maciej Sieczka <tutey at o2.pl>:
> Martin Landa wrote:
> > Hi,
> > right, should be fixed in CVS now.
> I had a moment to look into this again. The segfault is fixed - cool!
> However I think another problem remains. In the command:
> $ v.distance from=points to=roads from_type=point to_type=line
> from_layer=1 to_layer=1 dmax=-1 upload=cat column=road_cat to_column=cat
> the paramater to_column= is used while the upload=cat. In this case, an
> error should propably crop out, since to_column= is reserved for
> upload=to_attr only, and it should not be used without it.
> What do you think?
Hmm, not sure, using to_column option & use!=to_attr should not affect
the result (or?). So why to inform the user about that?;-)
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
