[GRASS-dev] r.out.gdal: GeoTIFF colortable malformed?
Maciej Sieczka
tutey at o2.pl
Sun Mar 11 17:31:52 EDT 2007
Glynn Clements wrote:
> Maciej Sieczka wrote:
>> GeoTIFFs exported with r.out.gdal appear blank in QGIS 0.8 [1].
> Did you specify type=Byte or type=UInt16?
On https://svn.qgis.org/trac/ticket/643 you can read it was:
r.out.gdal input=vegcover format=GTiff type=Byte output=vegcover.tif
> The default for CELL maps is
> Int32, and a 2^32 entry palette isn't feasible.
> $ r.out.gdal vegcover format=GTiff output=vegcover.tif
> ERROR 6: SetColorTable() only supported for Byte or UInt16 bands in TIFF format.
> Done!
> [gdalinfo shows no colour table.]
> $ r.out.gdal vegcover format=GTiff output=vegcover.tif type=Byte
> Done!
> [gdalinfo shows a colour table.]
> Even with type=, the COLOR_TABLE_RULE* values are bogus; all entries
> have zero for start, end and intensities:
> COLOR_TABLE_RULES_COUNT=6
> COLOR_TABLE_RULE_RGB_0=0.000000e+00 0.000000e+00 0 0 0 0 0 0
> COLOR_TABLE_RULE_RGB_1=0.000000e+00 0.000000e+00 0 0 0 0 0 0
> COLOR_TABLE_RULE_RGB_2=0.000000e+00 0.000000e+00 0 0 0 0 0 0
> COLOR_TABLE_RULE_RGB_3=0.000000e+00 0.000000e+00 0 0 0 0 0 0
> COLOR_TABLE_RULE_RGB_4=0.000000e+00 0.000000e+00 0 0 0 0 0 0
> COLOR_TABLE_RULE_RGB_5=0.000000e+00 0.000000e+00 0 0 0 0 0 0
> This is because:
> 1. vegcover doesn't use colour rules but a fixed palette:
> #0 first color
> 255 255 255
> 0
> 255 0 0
> 255 255 0
> 255 128 0
> 0 0 255
> 255 0 255
> 0 255 0
> [spearfish57/PERMANENT/colr/vegcover]
> 2. r.out.gdal is using the maximum value as the number of rules (hence
> the COLOR_TABLE_RULES_COUNT=6) rather than the value returned by
> G_colors_count().
> I've committed a fix for point #2, so vegcover.tif won't have
> COLOR_TABLE_RULES_COUNT or COLOR_TABLE_RULE_RGB_* tags.
Thank you. I'll report back when I try the fixed version.
Regards,
Maciek
