[GRASS-dev] portable.h elimination
Moritz Lennert
mlennert at club.worldonline.be
Tue Mar 13 17:44:49 EDT 2007
On Mon, March 5, 2007 14:06, Glynn Clements wrote:
> I've modified lib/vector/diglib to determine the byte ordering at run
> time, rather than generating the portable.h header file.
> The supplied test case passes. It might be useful to test it using dig
> files generated on an architecture with the opposite byte order (I
> have no way to test this). It might also be worth testing it on MinGW.
How should I test ?
Moritz
