[GRASS-dev] portable.h elimination
Glynn Clements
glynn at gclements.plus.com
Wed Mar 14 07:59:30 EDT 2007
Paul Kelly wrote:
> >> I've modified lib/vector/diglib to determine the byte ordering at run
> >> time, rather than generating the portable.h header file.
> >> The supplied test case passes. It might be useful to test it using dig
> >> files generated on an architecture with the opposite byte order (I
> >> have no way to test this). It might also be worth testing it on MinGW.
> > How should I test ?
> Thanks for reminding me about this Moritz - I'd looked at it both quite a
> while ago and more recently after Glynn posted about the portable.h
> changes. I don't think there's any change on MinGW - the portable test in
> the lib/vector/diglib Makefile always failed anyway - presumably that's
> why it was conditionalised on not running on MinGW. If it is forced to run
> anyway, I get the following output:
> For some reason (can't quite remember why) I changed test.c in the past to
> try and get this to work. ISTR someone suggested somewhere extra seeks
> were needed on Windows.
You need to seek when switching between reading and writing. Windows'
FILE structure only has a single buffer (rather than separate
read/write buffers), so you need to force it to flush/discard any
buffered data.
> This is what I changed:
Can you commit those, please.
> And with that the output from the test is now:
> ==============TEST=============
> gcc -L/c/grass/grass6/dist.i686-pc-mingw32/lib -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/grass/forgrass/lib -I/c/grass/forgrass/include -g -O2 -I/c/grass/forgrass/include -I/c/grass/forgrass/include -I/c/grass/grass6/dist.i686-pc-mingw32/include -o OBJ.i686-pc-mingw32/test test.c -lgrass_dig2 -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_rtree -lgrass_rtree \
> -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lgrass_datetime -lxdr -liberty -lws2_32 -lz
> cd OBJ.i686-pc-mingw32; PATH=".:/bin:/mingw/bin:/mingw/lib:/c/grass/forgrass/bin:/c/grass/forgrass/lib:/c/tcl/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/c/grass/forgrass/bin:/c/grass/forgrass/lib:/c/tcl/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Program Files/QuickTime/QTSystem/:/c/jed09916/bin:/c/grass/grass6/dist.i686-pc-mingw32/lib" ./test; diff ./test.tmp ../test.ok
> Binary files ./test.tmp and ../test.ok differ
> make: *** [OBJ.i686-pc-mingw32/test] Error 1
> i.e. the test files are still different, but it doesn't have lots of
> errors while running. I have no idea if/how that is significant!
The stream of errors indicates that what was read back doesn't match
what was written, i.e. a problem with low-level I/O.
The "diff" failure indicates that what was written wasn't what was
expected. This could be a text/binary issue (I don't see $(FMODE_OBJ)
in the link command); it could even be due to differences in
floating-point rounding (even if only the lowest bit of a double is
wrong, the test will still fail).
If adding $(FMODE_OBJ) to the test doesn't work, convert test.tmp and
test.ok to hex (with "od -t x ...") and compare the hex dumps.
