[GRASS-dev] Re: testing native winGRASS
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Mar 14 10:48:35 EDT 2007
On Wed, 14 Mar 2007, Moritz Lennert wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 13/03/07 23:34, Paul Kelly wrote:
>> Hello Moritz
>> On Tue, 13 Mar 2007, Moritz Lennert wrote:
>>> 1) Create location with projection values: location created but mapset
>>> (other than PERMANENT) invalid
>> Could you try the patch below for lib/gis/getl.c and see if GRASS can
>> then handle the newly created location? I think the problem is the
>> created location contains Windows line endings in some of the files and
>> other GRASS functions can't handle them. G_getl2() handles Windows line
>> endings whereas G_getl() does not. I have a hunch this may apply in many
>> places.
> I will try this tonight, but just to make clear what is going wrong:
> creating the location works and there is a valid PERMANENT mapset
> created whatever I do, but if (in the console window where you enter the
> name of the new location) I give a mapset name other than PERMANENT,
> this mapset is then created (together with PERMANENT), but when I try to
> enter it, I get an "invalid mapset" error, which is understandable since
> the mapset directory is empty except for a dbf directory (IIRC).
Ah OK. I believe the problem is this in lib/init/mke_mapset.c:
/* give the mapset a default window for the entire location */
sprintf(buffer,"cat '%s'/PERMANENT/DEFAULT_WIND > '%s'/'%s'/WIND",
location, location, mapset) ;
system(buffer) ;
but at the minute my mind has gone blank as to the portable way to replace
that. I general audit of calls to system() would have caught that if we're
able to get round to doing it I suppose.
Paul
