I've modified v.digit so that it no longer requires the form library (by incorporating the form code directly into v.digit). Let me know if there are any problems. With this change, it should be fully functional on native Windows (the standalone form utility doesn't work there). -- Glynn Clements <glynn at gclements.plus.com>
