[GRASS-dev] d.menu, d.ask
Thu Mar 15 00:36:24 EDT 2007
Glynn Clements wrote:
> The major outstanding issue is whether d.rast.edit needs to be able to
> pan around the map while it's running,
that would be very nice, as in practice you have to work on a small
zoomed in region.
> or whether it's sufficient to use a sequence of d.rast.edit commands
> interleaved with d.zoom or g.region commands.
sounds clunky. Maybe make use of the GRASS_REGION=";;;" enviro var and
write tcl "virtual" zoom controls? (&/or WIND_OVERRIDE)
Hamish
