[GRASS-dev] string madness
Sat Mar 17 17:59:12 EDT 2007
Markus Neteler wrote:
> g.gisenv set=DEBUG=3
> echo "SELECT * from zecche_BL2001_gis WHERE comune='Zoldo Alto' ORDER BY datacens" | db.select
> D2/3: col: datacens, nkcols 13, litetype : 2, sqltype 6
> "datacens" is the column in question.
	http://www.sqlite.org/cvstrac/fileview?f=sqlite/src/sqlite.h.in&v=1.198
says:
	#define SQLITE_INTEGER  1
	#define SQLITE_FLOAT    2
	/* #define SQLITE_TEXT  3  // See below */
	#define SQLITE_BLOB     4
	#define SQLITE_NULL     5
IOW, litetype == SQLITE_FLOAT, sqltype == DB_SQL_TYPE_DOUBLE_PRECISION.
If DBMI thinks that the column contains a float, trying to parse
YYYY-MM-DD as a float is going to fail.
