[GRASS-dev] Re: testing native winGRASS
Glynn Clements
glynn at gclements.plus.com
Sun Mar 18 19:09:08 EDT 2007
Moritz Lennert wrote:
> >>>> lib/vask/V_clear.c:63: system("clear");
> >>> Commented out.
> >> Note that there is G_clear_screen() if needed.
> > In that case, it should replace all occurrences of system("clear").
> > And it should be changed to use G_spawn(); no need for a shell (unless
> > "cls" is a shell built-in on Windows).
> I cannot find a cls.exe on my machine. Does that mean it is a shell
> built-in ?
It appears so; typing "help cls" in the shell provides documentation,
which implies that it's built in.
