[GRASS-dev] [bug #5499] (grass) bash scripts starting with #!/bin/sh
Sun Mar 18 19:49:35 EDT 2007
[this matters as the new Ubuntu uses [d]ash for #!/bin/sh not bash]
Maciek Sieczka via RT wrote:
> Another bunch of possible bashism, in regard too Hamish'es hints on
> how to avoid them.
(as collected from this list mostly)
> Hamish wrote:
> > use "=" not "==" for string compares
> These do not conform:
> d.correlate:  if [ "$name" == "" ] ; then
# use -z to test if string is zero-length, -n to test if non-zero length
if [ -z "$name" ] ; then
> d.correlate:if [ "$ok" == "no" ] ; then
# only use a single "=" for string compares
if [ "$ok" = "no" ] ; then
> d.polar:if [ $TOTALVALIDNUMBER == 0 ] ; then
# use -eq integer compare
if [ "$TOTALVALIDNUMBER" -eq 0 ] ; then
> d.vect.thematic:    if [ "`db.columns table=$table database=$database
>   driver=$driver | grep -i grassrgb`" == "" ] ; then
Use -z. Note d.vect.thematic also uses "let" in a several places which
needs to be changed to `expr`.
> g.mlist:  if [ "$itype" == "all" ] ; then
> r.fillnulls:r.mapcalc "MASK=if($TMP1.buf==2,1,null())"
"==" is ok within a r.mapcalc expression. Not a bug.
> r.plane:         if (dist==0) {
-eq
> r.plane:        if (typeflag==""){
-z
> v.rast.stats: r.mapcalc "MASK=if(${VECTOR}_${TMPNAME} == $i, 1,
> null())" 2> /dev/null
ok within r.mapcalc. Not a bug.
> Also, I guess (and only guess) that -+ and += would fail for non-Bash.
> There are some in r.tileset:
As Glynn already noted, r.tileset is written as a bash program, not a
unix shell script, and it is more work than I want to undertake to
rewrite it.
Hamish
