[GRASS-dev] Re: [GRASS-user] Compiling grass 6.2.1: i.class error
Hamish
hamish_nospam at yahoo.com
Mon Mar 19 01:37:45 EDT 2007
Glynn Clements wrote:
> > > Actually, a script using r.out.ppm, pnmcat and mplayer might add
> > > some I/O overhead, but that's likely to be less significant, given
> > > that xganim is limited to the amount of data which can be held in
> > > memory.
> > i.e. a replacement for r.out.mpeg.
> Not really. Conversion to MPEG-type video has significant overhead;
> xganim will often be used for one-off animation. Note that I'm talking
> about using mplayer to play a sequence of PPM files.
which is why I pointed to the ImageMagick tricks on the wiki page to
make animated GIFs or PNGs (MNG). (convert + display) less processor
overhead, but a lot more memory overhead.
http://grass.gdf-hannover.de/wiki/Movies
We probably just need a tool to output a series of frames. Once you have
that you can encode or slideshow in any number of ways using wrapper
scripts around that.
http://grass.gdf-hannover.de/wiki/Movies#Animate_to_files
Hamish
