[GRASS-dev] Re: testing native winGRASS
Moritz Lennert
mlennert at club.worldonline.be
Mon Mar 19 06:00:44 EDT 2007
On 19/03/07 01:02, Paul Kelly wrote:
> Hello Moritz,
> A few comments below.
> On Mon, 19 Mar 2007, Moritz Lennert wrote:
>>>> lib/gis/gishelp.c:55: system(buffer) ;
>>>> sprintf(buffer, "%%GRASS_PAGER%% %s", file) ; /*ifdef __MINGW32__*/
>>>> sprintf(buffer, "$GRASS_PAGER %s", file) ;/*else*/
>>> G_spawn(getenv("GRASS_PAGER"), getenv("GRASS_PAGER"), file, NULL);
>> done, but I get:
> Note that that now won't work on Windows (while it presumably did
> before!) because GRASS_PAGER is a shell built-in and we haven't done
> changed that yet...
> Same goes for the other usages of GRASS_PAGER.
Ok, so, should I revert this, or should we leave it as a motivation to
develop a GRASS_PAGER batch script ?
>> replaced by
>> G_convert_dirseps_to_host(Tmp_file), NULL);
> As well as not working on Windows as mentioned above, this will also be
> broken on Unix now for some circumstances as it will print the list of
> datum choices to stdout but print the prompts to stderr. So if you run
> something like
> g.proj -wi epsg=29900 > wkt.prj
> to write a WKT description of EPSG co-ordinate system 29900 to a text
> file, but want g.proj to interactively prompt you on the datum names,
> the list of datum names will be written into the file rather than
> printed to the screen with the other prompts.
So, should I revert or is there a better fix ? Unless we decide that any
form of prompting is "illegal" in modules ?
>>>> raster/r.average/main.c:94: if ((stat = system(command)))
>>>> sprintf (command, "%s -anC input=%s,%s fs=space > \"%s\"", STATS,
>>>> basemap->answer, covermap->answer, tempfile1); & #define STATS
>>>> "r.stats"
>>> sprintf(input_arg, "input=%s,%s", basemap->answer,
>>> covermap->answer);
>>> G_spawn_ex(STATS, STATS, "-anC", input_arg, "fs=space",
>>> SF_REDIRECT_FILE, 1, O_WRONLY|O_CREAT, tempfile, NULL);
>>>> raster/r.average/main.c:154: stat = system(command);
>>>> sprintf (command, "%s input=%s output=%s < \"%s\"", RECODE,
>>>> basemap->answer, outputmap->answer, tempfile2); & #define RECODE
>>>> "r.recode"
>>> sprintf(input_arg, "input=%s", basemap->answer);
>>> sprintf(output_arg, "output=%s", outputmap->answer);
>>> G_spawn_ex(RECODE, RECODE, input_arg, output_arg,
>>> SF_REDIRECT_FILE, 0, O_RDONLY, tempfile2, NULL);
>> Should we use G_spawn_ex even though it is not ported to Windows ?
> Well seeing the point of this audit was to fix occurences of system()
> that were broken on Windows, and that this one (like a lot of them) as
> far as I can see isn't actually broken, but the change would break it, I
> should think not! ;) It could do with being tidied up obviously but
> needs a bit more work.
Glynn seems to argue that we should try to avoid any calls to a shell...
>>>> raster/r.coin/inter.c:32: G_system("clear");
>>>> raster/r.coin/inter.c:51: G_system("clear");
>>> G_spawn("clear", "clear", NULL);
>> Should be G_clear_screen(). I guess I can just go ahead with this and
>> we can deal with the internals of G_clear_screen() later, or ?
> I think so. This actually is a case of something that currently is
> broken on Windows and will be fixed by the change.
At least some good ;-)
Moritz
