[GRASS-dev] Re: testing native winGRASS
Moritz Lennert
mlennert at club.worldonline.be
Wed Mar 21 10:22:52 EDT 2007
On 20/03/07 20:51, Paul Kelly wrote:
> First of all, I'm an idiot - "more" actually is a normal command on
> Windows, not a shell built-in. I was getting it confused with "type".
> But even with that, using G_spawn() to run it still doesn't work. I've
> done a bit of experimenting with it but not sure why. So I'm leaving
> G_system() in where it is working OK for now until we get that sorted.
But in any case this means that we shouldn't need a batch script for
calling "more", or ?
> Changes I've just made in CVS involve:
> Create region files in new user mapsets (other than PERMANENT) correctly
> (use G_get_default_window() and G_put_window())
> Create MYNAME file with fputs()
> Update interactive version of r.coin so it works:
> Added new G_copy_file() function to libgis to use instead of
> system("cp...")
> Change system("clear") to G_clear_screen()
> Remove checks for absolute paths and logic about saving report file to
> home directory - just save it to whatever filename the user gives.
> Quote parameters in call to r.stats using double quotes instead of
> single quotes so it works on Windows (this applies to cmd and inter
> versions of r.coin)
Great !
I have also committed your proposal for the null device definition, i.e.
Suggested:
> Index: gis.h
> RCS file: /home/grass/grassrepository/grass6/include/gis.h,v
> retrieving revision 1.42
> diff -u -r1.42 gis.h
> --- gis.h 6 Mar 2007 01:34:47 -0000 1.42
> +++ gis.h 20 Mar 2007 09:22:55 -0000
> @@ -145,8 +145,10 @@
> #define GRASS_DIRSEP '/'
> #ifdef __MINGW32__
> # define HOST_DIRSEP '\\'
> +# define G_DEV_NULL 'NUL:'
> #else
> # define HOST_DIRSEP '/'
> +# define G_DEV_NULL '/dev/null'
> #endif
So, what is priority now in trying to get winGRASS as quickly as
possible to release level ?
- Go through more of the audit results and Glynn's suggestions on how to
fiw them ?
Looking at what's left, there are a lot of G_spawn_ex cases. Then a few
which would need a G_vspawn_ex() or equivalent.
The others should be no problem, so I can deal with those.
- Implement G_spawn_ex for windows + G_vspawn_ex ?
- Continuing testing wingrass ?
Knowing that even though I am willing to try, it will take me a lot more
time to come to grips with G_spawn_ex than any of you. So, it's also a
question of efficient use of sparse resources ;-)
BTW: there is a call to r.stats in d.histogram which makes this module
fail in gis.m on windows ? Again it seems to be a quoting issue as the
error is something like "file or directory not found". Paul, as you did
this for r.coin, could you look into that ?
Moritz
