[GRASSGUI] Re: [GRASS-dev] wxgrass prototype
Moritz Lennert
mlennert at club.worldonline.be
Wed Mar 21 10:53:54 EDT 2007
On 21/03/07 15:43, Michael Barton wrote:
> On 3/21/07 7:39 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
>> And a few more remarks:
>> - When double-clicking on an already existing layer to make the
>> d.vect/d.rast window appear, this window does not contain the map name
>> of the map that was selected before. I think this should be the case, as
>> when you just want to modify one option, you don't want to always have
>> to reselect the map name
> I definitely agree. Using the autogenerated dialogs has considerable
> drawbacks at the moment. I don't know if these can be overcome with
> enhancements to menuform.py or whether this will turn out to be further
> reason for custom created dialogs for the few d.* commands.
Maybe the settings for each layer can be saved in some temporary file,
which could then also be the basis for saving a session ?
But this would mean enhancing the code generating the dialogs so that it
can take into account existing settings...
Moritz
