[GRASS-dev] changing data for parser
Michael Barton
michael.barton at asu.edu
Thu Mar 22 01:31:14 EDT 2007
menuform.py uses the xml text generated by ³<command>
interface-description² to create the autogenerated dialogs. This dates to
2001.
I was just reminded in a recent post to the grass developer list that there
is a richer interface description output called by ³<command> --tcltk². This
has been developed over the past year or so. I give an example below (part
of the output from ³d.vect tcltk²). We might want to consider switching the
autogenerated panels to be created by the tcltk code.
Besides being a richer set of descriptions (includes prompt for notebook
tabs and color picking dialogs), it looks easier to parse than the
interface description xml. It would also mean that we would not need sax.
Michael
======= --tcltk style interface description ==========
GRASS 6.3.cvs (spearfish60_test):~ > d.vect --tcltk
begin_dialog {d.vect} {
label {}
desc {Displays GRASS vector data in the active frame on the graphics
monitor.}
key {display}
add_flag 1 {
name {v}
desc {Run verbosely}
answer 0
label {}
guisection {}
add_flag 2 {
name {a}
desc {Get colors from map table column (of form RRR:GGG:BBB)}
answer 0
label {}
guisection {Colors}
add_flag 3 {
name {c}
desc {Random colors according to category number (or layer number if
'layer=-1' is given)}
answer 0
label {}
guisection {Colors}
add_flag 4 {
name {i}
desc {Use values from 'cats' option as line ID}
answer 0
label {}
guisection {Query}
add_flag 5 {
name {x}
desc {Don't add to list of vectors and commands in monitor (it won't be
drawn if the monitor is refreshed)}
answer 0
label {}
guisection {}
add_option 6 {
name {map}
type {name}
multi 0
desc {Name of input vector map}
required 1
options {}
answer {}
prompt {old,vector,vector}
label {}
guisection {}
add_option 7 {
name {type}
type {string}
multi 1
desc {Feature type(s)}
required 0
options {point,line,boundary,centroid,area,face}
answer {point,line,boundary,centroid,area,face}
prompt {}
label {Type}
guisection {}
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070321/a5cd0055/attachment.html
