[GRASS-dev] Allocating memory for a huge array
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Mar 22 16:45:08 EDT 2007
On Thu, 22 Mar 2007, Paul Kelly wrote:
>> unsigned int * H_Array;
>> H_Array=(unsigned int *)G_calloc(2^32, sizeof(unsigned int));
>> because in this way (unsigned int) with 32 bits I can manage 4 billions
>> cells, instead of 2 billions related to 32 bits as (traditional signed)
>> int.
> I think you're confusing the size of the array data type with the size of the
> array index. The array index is always a pointer of size size_t and can get
> as big as the system allows a size_t to be.
Sorry just thought of a way I could explain this more clearly. The amount
of values you can have in the array is equal to sizeof(unsigned int *).
This is exactly the same value as sizeof(int *), sizeof(short *), even
sizeof(char *) - they are all pointers of size size_t. In other words,
nothing to do with the data type that is actually stored in the array. I
used to be terribly confused about this and indeed introduced some bugs
into GRASS because of it* but am mostly over my confusion now ;)
Paul
* On 32-bit operating systems a size_t is 32 bits, but on 64-bit operating
systems it is 64 bits - make sense? So maybe an AMD64 and a 64-bit
compatible operating system is the solution to your problem?
