[GRASSGUI] Re: [GRASS-dev] d.rast still noisy
Fri Mar 23 16:05:42 EDT 2007
Michael Barton wrote:
> Do you want me to explicitly add @mapset for selecting items in the current
> maset (already the case for items chosen from other mapsets) in
> select.Select?
That would be a good idea.
Have you checked what happens when the current mapset *doesn't* come
first in the search path?
