[GRASS-dev] Re: [GRASS-user] 'where' sql command in d.vect and others
Seb spluque at gmail.com
Sat Mar 24 22:23:40 EDT 2007
On Sun, 25 Mar 2007 02:48:15 +0100,
Glynn Clements <glynn at gclements.plus.com> wrote:
> I suspect that this is a bug in G_recreate_command().
> What does "d.save -a" output?
This returns the following for the 'where' parameter:
where="str_3='"W Arctic"'"
exactly as it was entered in the display manager, which wouldn't work from
the command line or a script because the double quotes (within the single
quotes) are not escaped.
Cheers,
Seb
