[GRASS-dev] Header file management
Soeren Gebbert soerengebbert at gmx.de
Wed Mar 28 11:37:00 EDT 2007
Dear devs,
i have a question regarding the header file management in grass.
I'm implementing a new library in grass (gpde) and therefor i have created
new global header files.
AFAIK by default the global header files are located in grass6/include
and copied while the build process to $(GISBASE)/include/grass.
This has the side effect that the global header files are ignored by the
doxygen docu generation process of the grass libraries.
I would like to keep the global header files in the library directory, so they
can be included in the library doxygen documentation.
To assure the correct header file placement, the header files will be copied
from the library directory into the global header directories:
This entry in "grass6/lib/gpde/Makefile" will do the job:
MODULE_TOPDIR = ../..
EXTRA_LIBS=$(GISLIB) $(G3DLIB)
LIB_NAME = $(GPDE_LIBNAME)
include $(MODULE_TOPDIR)/include/Make/Lib.make
include $(MODULE_TOPDIR)/include/Make/Doxygen.make
default: headers lib
headers:
	for file in ./*.h ; do $(INSTALL_DATA) $$file ../../include/ ; done
	for file in ./*.h ; do $(INSTALL_DATA) $$file $(GISBASE)/include/grass/ ;done
#doxygen:
DOXNAME=gpde
If you think this approach is correct, i will move the gpde header files from
the include directory into the gpde library directory and modify the
Makefile.
Any suggestions are welcome.
Best regards
Soeren
