[GRASS-dev] Re: [GRASS-user] problem with v.edit tool=merge
Maciej Sieczka tutey at o2.pl
Fri Mar 30 03:41:58 EDT 2007
Martin Landa wrote:
> Hi,
> no, there is another problem. Merge tool has been updated and snap
> tool not. Snap tool in v.edit is very simple:
> 1) select lines
> 2) snap *first two* lines from the list [regardless of threshold -- it
> is a bug]
> see [1,2]
> Behaviour of merge tool is a little bit different. It tries to merge
> *all* selected lines.
> So there is *important* question for future development of v.edit,
> should be snap tool updated (snap all selected lines) or merge tool
> modified according to current simplified snap tool (i.e. merge only
> first two selected lines and  leave rest of selected lines untouched)?
I'd vote for selective merge and snap tools. One could repeat v.edit in
a loop in order to merge or snap more than two lines, is that correct?
Maciek
