Martin Landa wrote: > PS: only one small note > > d.mon start=PS;d.vect vegcover type=area ren=c -c;d.mon stop=PS > > the output contains redundant "rays" [1] > > [1] http://gama.fsv.cvut.cz/~landa/temp/grass/map.png I don't understand what you are saying; can you explain? -- Glynn Clements <glynn at gclements.plus.com>
