[GRASS-dev] [bug #2793] (grass) v.segment: side offset is ignored
Markus Neteler via RT
grass-bugs at intevation.de
Tue May 1 06:14:22 EDT 2007
https://intevation.de/rt/webrt?serial_num=2793
Apparently Vect_point_on_line() lacks support for side offset. Indeed, it
doesn't even have such a parameter.
We can now either remove all the side_offset stuff from the manual page or
convince a developer to expand Vect_point_on_line(). The functions used in
v.buffer/v.parallel might be helpful in this regard.
Markus
-------------------------------------------- Managed by Request Tracker
