Hi, I have a network of streams (say, Spearfish or better the new NC data set at http://mpa.itc.it/grasstutor/data_menu3rd.phtml ) and want to extract a single stream system. Names are lacking, is there any trick to extract topologically connected lines into a new map? Markus
