[GRASS-dev] d.rast.edit: can't remove some temp files
Wed May 2 06:36:15 EDT 2007
Maciej Sieczka wrote:
> The tcl/tk d.rast.edit in current 6.3 CVS prints following info to the
> output after "Exit":
> Raster map <tmp.d.rast.edit> not found
> <tmp.d.rast.edit> nothing removed
> Is that OK?
Yes. It always removes the temporary map on exit, regardless of
whether or not it used it.
