[GRASS-dev] font path question for Linux and Windows
Agustin Diez Castillo
Agustin.Diez at uv.es
Wed May 2 06:48:44 EDT 2007
mdfind 'kMDItemContentType = "*truetype*"'
Finds all the truetype fonts on my Computer, even those inside an
Application folder or on devices attached to it.
/System/Library/Fonts/Apple LiGothic Medium.dfont
/System/Library/Fonts/AppleGothic.dfont
/System/Library/Fonts/Courier.dfont
/System/Library/Fonts/Geneva.dfont
/System/Library/Fonts/Helvetica.dfont
/System/Library/Fonts/Keyboard.dfont
/System/Library/Fonts/LastResort.dfont
/System/Library/Fonts/LucidaGrande.dfont
/System/Library/Fonts/Monaco.dfont
/System/Library/Fonts/Symbol.dfont
/System/Library/Fonts/Times.dfont
/System/Library/Fonts/ZapfDingbats.dfont
/System/Library/Fonts/儷黑 Pro.ttf
/System/Library/Fonts/华文细黑.ttf
/System/Library/Fonts/华文黑体.ttf
/Library/Fonts/tt9830z_.ttf
/Library/Fonts/AmericanTypewriter.dfont
/Library/Fonts/Apple Chancery.dfont
/Library/Fonts/Apple Symbols.ttf
/Library/Fonts/Baskerville.dfont
/Library/Fonts/BigCaslon.dfont
/Library/Fonts/Chalkboard.ttf
/Library/Fonts/ChalkboardBold.ttf
/Library/Fonts/Cochin.dfont
/Library/Fonts/Copperplate.dfont
/Library/Fonts/Didot.dfont
/Library/Fonts/Futura.dfont
/Library/Fonts/GillSans.dfont
/Library/Fonts/HelveticaNeue.dfont
/Library/Fonts/Herculanum.dfont
/Library/Fonts/Hoefler Text.dfont
/Library/Fonts/MarkerFelt.dfont
/Library/Fonts/Apple LiSung Light.dfont
/Library/Fonts/BiauKai.dfont
/Library/Fonts/NISC18030.ttf
/Library/Fonts/儷宋 Pro.ttf
/Library/Fonts/华文仿宋.ttf
/Library/Fonts/华文宋体.ttf
/Library/Fonts/华文楷体.ttf
/Library/Fonts/#Gungseouche.dfont
/Library/Fonts/#HeadlineA.dfont
/Library/Fonts/#PCmyoungjo.dfont
/Library/Fonts/#Pilgiche.dfont
/Library/Fonts/AppleMyungjo.dfont
/Library/Fonts/AlBayan.ttf
/Library/Fonts/AlBayanBold.ttf
/Library/Fonts/ArialHB.ttf
/Library/Fonts/ArialHBBold.ttf
/Library/Fonts/Ayuthaya.ttf
/Library/Fonts/Baghdad.ttf
/Library/Fonts/CharcoalCY.dfont
/Library/Fonts/Corsiva.ttf
/Library/Fonts/CorsivaBold.ttf
/Library/Fonts/DecoTypeNaskh.ttf
/Library/Fonts/DevanagariMT.ttf
/Library/Fonts/DevanagariMTBold.ttf
/Library/Fonts/EuphemiaCASBold.ttf
/Library/Fonts/EuphemiaCASItalic.ttf
/Library/Fonts/EuphemiaCASRegular.ttf
/Library/Fonts/GenevaCY.dfont
/Library/Fonts/GujaratiMT.ttf
/Library/Fonts/GujaratiMTBold.ttf
/Library/Fonts/Gurmukhi.ttf
/Library/Fonts/HelveticaCY.dfont
/Library/Fonts/InaiMathi.ttf
/Library/Fonts/Krungthep.ttf
/Library/Fonts/Optima.dfont
/Library/Fonts/Papyrus.dfont
/Library/Fonts/Skia.dfont
/Library/Fonts/Zapfino.dfont
/System/Library/Fonts/Geeza Pro Bold.ttf
/System/Library/Fonts/Geeza Pro.ttf
/System/Library/Fonts/Osaka.dfont
/System/Library/Fonts/OsakaMono.dfont
/Library/Fonts/Kai.dfont
/System/Library/Fonts/Hei.dfont
/Library/Fonts/KufiStandarGK.ttf
/Library/Fonts/MshtakanBold.ttf
/Library/Fonts/MshtakanBoldOblique.ttf
/Library/Fonts/MshtakanOblique.ttf
/Library/Fonts/MshtakanRegular.ttf
/Library/Fonts/Nadeem.ttf
/Library/Fonts/NewPeninimMT.ttf
/Library/Fonts/NewPeninimMTBold.ttf
/Library/Fonts/NewPeninimMTBoldInclined.ttf
/Library/Fonts/NewPeninimMTInclined.ttf
/Library/Fonts/PlantagenetCherokee.ttf
/Library/Fonts/Raanana.ttf
/Library/Fonts/RaananaBold.ttf
/Library/Fonts/Sathu.ttf
/Library/Fonts/Silom.ttf
/Library/Fonts/Thonburi.ttf
/Applications/rsi/idl_6.2/resource/fonts/tt/tt0003m_.ttf
/Volumes/LaCieDisk/Users/Shared/cosas de Smigol/Library/Perl/5.8.1/
darwin-thread-multi-2level/VRML/fonts/Amrigoi.ttf
+ 1000 fonts
and
mdls /Library/Fonts/Silom.ttf, writes the metadata
/Library/Fonts/Silom.ttf -------------
kMDItemAttributeChangeDate = 2006-08-11 10:56:25 +0200
kMDItemContentCreationDate = 2006-07-02 17:20:18 +0200
kMDItemContentModificationDate = 2006-07-02 17:20:18 +0200
kMDItemContentType = "public.truetype-ttf-font"
kMDItemContentTypeTree = (
"public.truetype-ttf-font",
"public.truetype-font",
"public.font",
"public.data",
"public.item"
kMDItemCopyright = "© 1992-2003 Apple Computer, Inc."
kMDItemDisplayName = "Silom.ttf"
kMDItemFonts = (Silom)
kMDItemFSContentChangeDate = 2006-07-02 17:20:18 +0200
kMDItemFSCreationDate = 2006-07-02 17:20:18 +0200
kMDItemFSCreatorCode = 0
kMDItemFSFinderFlags = 0
kMDItemFSInvisible = 0
kMDItemFSIsExtensionHidden = 0
kMDItemFSLabel = 0
kMDItemFSName = "Silom.ttf"
kMDItemFSNodeCount = 0
kMDItemFSOwnerGroupID = 80
kMDItemFSOwnerUserID = 0
kMDItemFSSize = 250996
kMDItemFSTypeCode = 0
kMDItemID = 227671
kMDItemKind = "Windows TrueType font"
kMDItemVersion = "10.4d5e1"
On May 2, 2007, at 4:18 AM, Glynn Clements wrote:
> William Kyngesburye wrote:
>> I just had a chance to check OSX 10.3 (Panther) X11 - fontconfig is
>> present. For OSX Panther, X11 is v1.0, before that (OSX 10.2 and
>> below) it was a beta and is not available for download any more, as
>> far as I can tell. I think the betas must be where fontconfig wasn't
>> a part of Apple's X11 package (and I'm sure it wasn't at first).
>> So, using fc-list on OSX, if it's available, for mkftcap is
>> reasonable, for now.
> Is it possible to filter any non-TrueType fonts from the output? Or
> are there not enough TrueType fonts to worry about?
> We can probably tolerate a few bogus entries in an auto-generated
> freetypecap file; the user can always remove entries which don't work.
> However, on my system, "fc-list :outline file" generates 102 entries;
> 51 are .ttf files and 51 are .pfa/.pfb files, which is too high a
> signal-to-noise ratio.
> That doesn't matter on Linux, as I can just ignore anything which
> doesn't have a .ttf extension. For OSX, we'll need to find some other
> way unless the number of false positives in the original fc-list
> output is low.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070502/49c1e989/attachment.html
