[GRASS-dev] ps.map: raster always under vector map?
Wed May 2 08:51:58 EDT 2007
Markus Neteler wrote:
> > > >>> Bear in mind that the raster map is always opaque, so it will obscure
> > > >>> anything which is drawn beneath it.
> > > >> Markus:
> > > >>> That's exactly what I need: in my case the raster map contains a few
> > > >>> cells only, but I need it on top to not be covered by vector contour
> > > >>> lines etc.
> > > >>> Maybe ps.map's raster command needs an additional parameter "ontop" or
> > > >>> something like this? Hacking C code as Hamish suggests might be asked
> > > >>> too much for the average user.
> > > >> are the null areas solid white, not transparent?
> > > > They are transparent. All fine.
> > > Of course I was too hasty. Nothing fine.
> > > > Just that the tons of contour
> > > > lines cover the scarse raster areas in the raster maps. That's
> > > > why I need them on top of the dense contour lines.
> > > ... and it seems that NULL is not respected by ps.map (as you will know
> > > already).
> > For masked images, you need to use the one-operand form of the "image"
> > operator with an image dictionary; see the RASTERMASK procedure in
> > lib/psdriver/psdriver.ps for an example. This requires support for
> > level 3 PostScript (present in GhostScript for a few years now; I
> > don't know about printers).
> > Regarding the generation of the image data (ps/ps.map/ps_raster.c), a
> > masked image needs 2 (mono) or 4 (RGB) components, with the mask byte
> > first (i.e. AARRGGBB); see lib/psdriver/Raster.c.
> I am afraid that I am not able to implement this.
Try the attached patch.
It only works with single rasters, not R/G/B groups. Also, the masked
flag is currently hard-coded on; ultimately, this would need to be
made into an option to the raster/rgb/group commands.
Index: ps/ps.map/ps_raster.c
RCS file: /grassrepository/grass6/ps/ps.map/ps_raster.c,v
retrieving revision 1.5
diff -u -r1.5 ps_raster.c
--- ps/ps.map/ps_raster.c	8 Jan 2007 07:25:26 -0000	1.5
+++ ps/ps.map/ps_raster.c	2 May 2007 12:47:53 -0000
@@ -65,6 +65,7 @@
     int i, n, r, g, b, rr, gg, bb, row, col, doing_color;
     RASTER_MAP_TYPE map_type, grp_map_type[3];
     void *cellbuf=NULL, *cbuf[3], *ptr;
+    int masked = 1;
     if (!PS.do_raster && !grp.do_group) return 1;
@@ -84,7 +85,35 @@
     fprintf(PS.fp, "%d %d scale\n",
 	(int)(PS.map_pix_wide + 0.5), (int)(PS.map_pix_high + 0.5));
+    if (masked)
+    /* make strings to hold image RGB values */
+    if (doing_color) fprintf(PS.fp, "/DeviceRGB setcolorspace\n");
+    else	     fprintf(PS.fp, "/DeviceGray setcolorspace\n");
+    if (doing_color) fprintf(PS.fp, "/imgstrg cw 4 mul string def\n");
+    else	     fprintf(PS.fp, "/imgstrg cw 2 mul string def\n");
+    fprintf(PS.fp, "4 dict dup begin\n");
+    fprintf(PS.fp, "/ImageType 3 def\n");
+    fprintf(PS.fp, "/InterleaveType 1 def\n");
+    fprintf(PS.fp, "/DataDict 7 dict def\n");
+    fprintf(PS.fp, "/MaskDict 6 dict def\n");
+    fprintf(PS.fp, "MaskDict begin\n");
+    fprintf(PS.fp, "/ImageType 1 def\n");
+    fprintf(PS.fp, "/Width cw def\n");
+    fprintf(PS.fp, "/Height ch def\n");
+    fprintf(PS.fp, "/ImageMatrix [cw 0 0 ch neg 0 ch] def\n");
+    fprintf(PS.fp, "/BitsPerComponent 8 def\n");
+    fprintf(PS.fp, "/Decode [0 1] def\n");
+    fprintf(PS.fp, "end\n");
+    fprintf(PS.fp, "MaskDict DataDict copy begin\n");
+    if (doing_color) fprintf(PS.fp, "/Decode [0 1 0 1 0 1] def\n");
+    fprintf(PS.fp, "/DataSource {currentfile imgstrg readhexstring pop} def\n");
+    fprintf(PS.fp, "image\n");
+    else
     if (doing_color) fprintf(PS.fp, "/imgstrg cw 3 mul string def\n");
     else	     fprintf(PS.fp, "/imgstrg cw string def\n");
@@ -93,6 +122,7 @@
     fprintf(PS.fp, "{currentfile imgstrg readhexstring pop}\n");
     if (doing_color) fprintf(PS.fp, "false 3 colorimage\n");
     else	     fprintf(PS.fp, "image\n");
     /* let user know what's happenning */
     if (PS.do_raster)
@@ -114,31 +144,62 @@
 	    if ((row % PS.row_delta) == 0)
 	    {   ptr = cellbuf;
 		for (col = 0; col < PS.w.cols; col += PS.col_delta)
 	            G_get_raster_color(ptr, &r, &g, &b, &PS.colors, map_type);
-		    /* if color raster */
-		    if (doing_color)
+		    if (masked)
-		        fprintf(PS.fp, "%02X%02X%02X", r, g, b);
-	                if (++n == 13)
-		            n = 0;
-		            fprintf(PS.fp, "\n");
+			int nul = G_is_null_value(ptr, map_type) ? 0xFF : 0x00;
+			/* if color raster */
+			if (doing_color)
+			    fprintf(PS.fp, "%02X%02X%02X%02X", nul, r, g, b);
+			    if (++n == 9)
+				n = 0;
+				fprintf(PS.fp, "\n");
-		    /* if grey raster */
+			/* if grey raster */
+			else
+			    fprintf(PS.fp, "%02X%02X", nul,
+				    (int)(.3 * (double)r + .59 * (double)g +
+					  .11 * (double)b));
+			    if (++n == 19)
+				n = 0;
 		    else
-		        fprintf(PS.fp, "%02X",
-		            (int)(.3 * (double)r + .59 * (double)g +
-				  .11 * (double)b));
-	                if (++n == 39)
-		            n = 0;
+			if (doing_color)
+			    fprintf(PS.fp, "%02X%02X%02X", r, g, b);
+			    if (++n == 13)
+				n = 0;
+			else
+			    fprintf(PS.fp, "%02X",
+			    if (++n == 39)
+				n = 0;
 		    ptr = G_incr_void_ptr(ptr, G_raster_size(map_type) * PS.col_delta);
