[GRASS-dev] v.digit crash
Markus Neteler
neteler at itc.it
Wed May 2 16:46:53 EDT 2007
On Wed, May 02, 2007 at 08:51:32PM +0200, Markus Neteler wrote:
> HI,
> I managed to crash the new v.digit by editing the "streams"
> map of the new NC dataset. I tried to insert a new point
> (outlet), then
> g.copy vect=streams,mystreams
> v.digit mystreams
> X Error of failed request: BadAlloc (insufficient resources for operation)
> Major opcode of failed request: 53 (X_CreatePixmap)
> Serial number of failed request: 4353
> Current serial number in output stream: 4361
> strace v.digit mystreams
> write(8, "\3\30\2\0\313\0\0\4\16\0\2\0\313\0\0\4", 16) = 16
> read(8, "\1\0\375\t\3\0\0\0!\0\0\0\1\0\1\1\377\377\377\377\0\0\0"..., 32) = 32
> read(8, "\177\200\301\0\177\200\301\0\0\0\37\10", 12) = 12
> read(8, "\1\30\376\t\0\0\0\0\242\0\0\0\4\0C\1a\256\26\0\0\0\0\0"..., 32) = 32
> write(8, "\10\30\2\0\313\0\0\4>\0\7\0\303\0\0\4\277\0\0\4\177\0\0"..., 188) = 188
> write(7, "\0", 1) = 1
> futex(0x83b93e8, FUTEX_WAKE, 1) = 1
> futex(0x8705388, FUTEX_WAKE, 1) = 1
> futex(0x870538c, FUTEX_WAIT, 471, NULL) = -1 EAGAIN (Resource temporarily unavailable)
> futex(0x83b93e8, FUTEX_WAKE, 1) = 0
> gettimeofday({1178131672, 506046}, {4294967176, 0}) = 0
> ioctl(8, FIONREAD, [64]) = 0
> read(8, "\17\360\377\t\313\0\0\4\1\2\0\0\337\2\0\0\377\177\0\0\223"..., 64) = 64
> futex(0x870538c, FUTEX_WAIT, 473, NULL) = -1 EAGAIN (Resource temporarily unavailable)
> gettimeofday({1178131672, 507598}, {4294967176, 0}) = 0
> write(8, "5\30\4\0\303\0\0\4\275\0\0\4\21\0\340\1F\0\5\0\303\0\0"..., 1424) = 1424
> futex(0x870538c, FUTEX_WAIT, 475, NULL) = -1 EAGAIN (Resource temporarily unavailable)
> gettimeofday({1178131672, 509871}, {4294967176, 0}) = 0
> ioctl(8, FIONREAD, [288]) = 0
> read(8, "\0\v;\n\303\0\0\4\0\0005\0\0\0\0\0\20\0\0\0\235q\t\10\0"..., 288) = 288
> open("/usr/share/X11/XErrorDB", O_RDONLY) = 9
> fstat64(9, {st_mode=S_IFREG|0644, st_size=37949, ...}) = 0
> read(9, "! $Xorg: XErrorDB,v 1.3 2000/08/"..., 37949) = 37949
> close(9) = 0
> brk(0xbf45000) = 0xbf45000
> write(2, "X Error of failed request: BadA"..., 78X Error of failed request: BadAlloc (insufficient resources for operation)
> ) = 78
> write(2, "Major opcode of failed request: "..., 35Major opcode of failed request: 53) = 35
> write(2, " (X_CreatePixmap)\n", 18 (X_CreatePixmap)
> ) = 18
> write(2, " ", 2 ) = 2
> write(2, "Serial number of failed request:"..., 38Serial number of failed request: 2619) = 38
> write(2, "\n ", 3
> ) = 3
> write(2, "Current serial number in output "..., 45Current serial number in output stream: 2627) = 45
> write(2, "\n", 1
> ) = 1
> exit_group(1) = ?
> Process 26510 detached
> I see that it tried to open the database table form then zap.
> v.db.connect -p mystreams
> Vector map <mystreams> is connected by:
> layer <1> table <mystreams> in database </home/neteler/grassdata/nc_spm_04/sqlite/sqlite.db> through driver <sqlite> with key <cat>
> Please suggest how to debug this one.
Digging further into this, I found out that it doesn't crash with the DBF
driver. So it is related to the SQLite driver.
Here some more debugging stuff:
http://mpa.itc.it/markus/tmp/vdigit_settings_sqlite.png
(how the table definition looks like in v.digit - all 99999 lengths!)
DEBUG=2 output, put here to not make the mail too long:
http://mpa.itc.it/markus/tmp/vdigit_settings_sqlite.txt
There are various size=99999 there which come from
db/drivers/sqlite/describe.c
113 fsize = 99999; /* sqlite doesn't care, it must be long enough to
114 satisfy tests in GRASS */
Last year I changes fsize from -1 to 99999 for v.in.ascii:
2006-07-04 11:24 markus
* describe.c: define sufficient length to make v.in.ascii functional
So far it worked. The trick seems to be to get it fixed for the form in
v.digit.
Markus
