[GRASS-dev] d.vect kills d.mon
Glynn Clements
glynn at gclements.plus.com
Wed May 2 20:22:01 EDT 2007
Markus Neteler wrote:
> mysterious day: I used v.clean on a map to break/snap/rmdupl
> and a topologically correct map is generated. But looking at
> it, d.vect kills x0:
Hamish made some changes to icon plotting in d.vect yesterday, so
those would be the prime suspect:
RCS file: /grassrepository/grass6/display/d.vect/plot1.c,v
Working file: plot1.c
head: 1.32
branch:
locks: strict
access list:
keyword substitution: kv
total revisions: 33; selected revisions: 3
description:
revision 1.32
date: 2007/05/02 10:42:34; author: hamish; state: Exp; lines: +2 -1
centroids always use default color to stand out from underlying area
revision 1.31
date: 2007/05/02 10:04:39; author: hamish; state: Exp; lines: +68 -125
bugfix: wasn't calculating new x,y for icon if colors were off (potentially nasty)
simplification: use D_symbol() to plot symbols
speed: only plot symbols which are in the graphics frame (massive speedup for LIDAR)
readability: change "rgb" variable name and set it using boolean values
revision 1.20.4.1
date: 2007/05/02 10:13:51; author: hamish; state: Exp; lines: +4 -3
bugfix: wasn't calculating new x,y for icon if colors were offr
(potentially nasty, probably never triggered)
> strace d.vect myroads_net col=red
> _llseek(6, 147456, [147456], SEEK_SET) = 0
> read(6, "\252\327\353\307\353>\"A\274\222\250\200\301\311RA\v\2"..., 4096) = 139
> _llseek(6, 147595, [147595], SEEK_SET) = 0
> rt_sigaction(SIGINT, {SIG_IGN}, {SIG_DFL}, 8) = 0
> rt_sigaction(SIGQUIT, {SIG_IGN}, {SIG_DFL}, 8) = 0
> write(4, "\0\0\177\6\377\0\0\177\6\377\0\0\177\6\377\0\0\177\6\377"..., 1484) = 1484
> read(5, "", 1) = 0
> write(2, "ERROR eof from graphics driver.\n", 32ERROR eof from graphics driver.
> ) = 32
> exit_group(1) = ?
> Process 27067 detached
> Not sure where "ERROR eof from graphics driver" originates from, probably
> lib/raster/rem_io.c?
Yes.
Debugging display commands is easier using direct rendering, as the
task isn't split between multiple processes (the client and the
display driver). E.g.:
$ GRASS_RENDER_IMMEDIATE=TRUE gdb d.vect
> run myroads_net col=red
