[GRASS-dev] problems with mkftcap
William Kyngesburye
woklist at kyngchaos.com
Wed May 2 21:32:17 EDT 2007
On May 2, 2007, at 8:17 PM, Hamish wrote:
> William Kyngesburye wrote:
>> Here's a small clip of the raw fc-list output:
>> /System/Library/Fonts/Times.dfont: :index=0
>> /Library/Fonts/Arial Narrow: :index=0
>> /System/Library/Fonts/ヒラ゠゙ノ角ゴ Std W8.otf: :index=0
>> /System/Library/Fonts/Apple LiGothic Medium.dfont: :index=0
>> /Library/Fonts/Arial Rounded Bold: :index=0
>> /Library/Fonts/Times New Roman: :index=0
>> /Library/Fonts/Andale Mono: :index=0
>> /System/Library/Fonts/ZapfDingbats.dfont: :index=0
>> /System/Library/Fonts/Hei.dfont: :index=0
>> Arial Narrow, Arial Rounded Bold, Times New Roman and Andale Mono
>> disappear after the sed.
> replace spaces in font names with underscores?
Not a good idea - if you mean renaming the font files. These are
standard fonts supplied with OSX. Renaming them can create possible
OS update problems.
If I take enough time to let my brain process the sed command, it
looks like it's something in:
that is, the file extension is not optional. Spaces are OK in that.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
