[GRASS-dev] Can't get font face index to work
William Kyngesburye woklist at kyngchaos.com
Thu May 3 01:33:54 EDT 2007
On May 2, 2007, at 11:29 PM, Glynn Clements wrote:
>> Actually, I expect using a name from the freetypecap file to
>> result in
>> the index being ignored. parse_freetypecap() strips the index so that
>> it can check for file existence, then returns the stripped version.
> This should now be fixed.
Progress!
These work (no warnings, and draw correct face):
Arial Narrow:/Library/Fonts/Arial Narrow:utf-8:
Times1:/System/Library/Fonts/Times.dfont|1:utf-8:
But these give the "WARNING: unable to open font map '...'":
Arial Narrow 0:/Library/Fonts/Arial Narrow|0:utf-8:
ArialNarrow0:/Library/Fonts/Arial Narrow|0:utf-8:
Times 1:/System/Library/Fonts/Times.dfont|1:utf-8:
There appear to be some <space> issues with specifying an index.
I haven't tried these by path.  Getting sleepy...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
