[GRASS-dev] d.vect.thematic: v.univar.sh -> v.univar?
Markus Neteler
neteler at itc.it
Thu May 3 01:38:07 EDT 2007
On Wed, May 02, 2007 at 09:52:06PM -0500, Daniel Calvelo wrote:
> Markus, could you try the version attached? I think I got it right but
> can't access a CVS build right now, so v.univar -e is unavailable for
> me right now.
> If ok, I'll commit to HEAD.
This version would revert all recent g.message changes.
It looks like that you worked on an older file version?
Markus
> Daniel.
> On 5/2/07, Markus Neteler <neteler at itc.it> wrote:
> >It seems to be slightly more complicated (I tried), so I
> >leave it for now.
> >Markus
> >On Tue, May 01, 2007 at 02:49:14PM -0700, Michael Barton wrote:
> >> If it does extended stats now and the output is the same, it should be an
> >> easy switch.
> >> Michael
> >> On 5/1/07 8:25 AM, "Markus Neteler" <neteler at itc.it> wrote:
> >> > Hi,
> >> > can we safely change v.univar.sh -> v.univar in d.vect.thematic?
> >> > This might speed up calculations...
> >> > Markus
> >> __________________________________________
> >> Michael Barton, Professor of Anthropology
> >> School of Human Evolution & Social Change
> >> Center for Social Dynamics & Complexity
> >> Arizona State University
> >> phone: 480-965-6213
> >> fax: 480-965-7671
> >> www: http://www.public.asu.edu/~cmbarton
> >Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> >FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
> >MPBA - Predictive Models for Biol. & Environ. Data Analysis
> >Via Sommarive, 18 - 38050 Povo (Trento), Italy
> >_______________________________________________
> >grass-dev mailing list
> >grass-dev at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass-dev
> -- Daniel Calvelo Aros
