[GRASS-dev] Re: d.vect changes
Otto Dassau
otto.dassau at gmx.de
Thu May 3 01:56:17 EDT 2007
Hi Markus,
On Thu, 3 May 2007 07:47:59 +0200
Markus Neteler <neteler at itc.it> wrote:
> On Thu, May 03, 2007 at 03:01:46PM +1200, Hamish wrote:
> > Markus wrote:
> > > d.vect kills x0
> > > strace d.vect myroads_net col=red
> > don't know, can you reproduce it with a spearfish map?
> > make distclean? ;)
> It happens with Spearfish. Just try my new v.net.path
> example in the description.html.
> BTW: the v.clean step therein fails - it does NOT properly
> connect the lines. Sigh.
I don't know your example, but I had similar problems some time ago because I
used a wrong tool order. As far as I remember the one below worked for me
and connected all lines.
v.clean in=xx out=xx tool=snap,break thres=xx
regards,
Otto
> Markus
