Markus Neteler wrote: > since only SQLITE_INTEGER, SQLITE_TEXT, and SQLITE_FLOAT are > supported, we could define the typical length for these fields > (based on what the DBF driver does or the PostgreSQL driver). > > Attached a patch which cures the problem. If ok, I will submit. Seems okay. -- Glynn Clements <glynn at gclements.plus.com>
